1 - 9 of 9 Posts
AEM series 2 ecu.
Boxed unused since I bought it.
Complete with new AEM CAS disc.
Only selling due to upgrading to an Infinity-10.
More features than Link including 6 coil drivers, fuel/oil pressure protection etc.
£900 ono.
Will also work with 300zx and RB25.
Discussion Starter · #2 ·
Also have 2 AEM serial gauges which connect to this ecu.
Can do a deal with the ecu or sell for £130 each.
Troubles with early series 1 units reading CAS till they brought out their CAS disc.
Got a bad reputation in the UK Skyline world over that.
Series 2 is a great unit. Millen was 2nd overall at Pikes Peak in 2013 using a series 2.
Very well featured for the price.
From what I've read they run OK for normal rpm with the disc but on a high rpm high power build I would run a crank trigger. You can configure any type of pickup in the software quite easily.
They probably just change the cas disc cause they can't read the standard disc good enough.
But the problem still remains that it's belt driven so it'll work just as good/bad as a standard cas on a ecu that supports it.
as far as I know is there only a AEM Series 2 ECU fitting BNR32 / BCNR33, not for the BNR34?
So I think this one will fit directly BNR32 / BCNR33?
1 - 9 of 9 Posts
