1 - 10 of 10 Posts
As above, Just cleaned them due to slight hesitancy during acceleration and what a difference. Amazing! :chuckle:
The AFM for the rear turbo was the dirtiest, I guess due to the crankcase ventilation system.
Administrator
Once in ten years. What did you do? Remove and spray with brake cleaner?
Carb cleaner works a treat as this is something I have used for a number of years and the car always runs a lot smoother after a good clean up. Make sure you use good filters though as ones with poor filtration will clog up the afm.
1 - 10 of 10 Posts
