1 - 9 of 9 Posts
I am looking at my options for a boost controller. when buying a after market boost controller is there special feature or type I should look out for, for the rb26 in r32
Skyline Section Manager
You need a closed loop system running a PWM solenoid rather than an open manual bleed tap.
Anything like this would suit you well.
i used greddy spec 2 before and it was easy to use. or Gizzmo- heard good recommendations on this. otherwise apexi avcr as FRRACER said
general the twin solenoid ones are A LOT more stable than the single ones (think blitz type r rather than type s)
you can tell the twin solenoid version because the solenoid looks massive in comparison :)
I have a problem with my evc-s.... Whats the parameters for boost and max boost??? I have offset, overboost and response... Hks manual doesn' t help a lot :(
1 - 9 of 9 Posts
