Hi all I have a loud worn bearing sound from the Air Con Pump pully when Air Con turned off or on if I remove the Air Con belt all is ok. Can I get the Air Con pully on its own or do i need the hole lot.
thanks.
Hi, you can buy pully on its own, but you can also change bearing to that old one. At least i did that on mine. And it works just fine.
You should get the bearing almost any local spare part shop who sell bearings. It´s standard bearing, there is number on a side of the bearing. Just ask new bearing with the same numbers. When you take the pully out, you should see the numbers on the bearing, just have to clean it well. Something like one letter and four numbers.
