1 - 16 of 16 Posts
Hi,
I bought this for my R32 GTR but it needs 18” wheels and I’m running 17’s, so went for a V-Spec Brembo upgrade instead.
Comes with Calipers, discs, mounting brackets, bolts, and Hel lines. All new and unused.
£2000
269160
269161
269162
269163
269164
269165
Thanks,
Brian.
Hi,
£2000
View attachment 269093 View attachment 269094 View attachment 269095 View attachment 269096 View attachment 269097 View attachment 269098
Thanks,
Brian.
Hello Brian, I am interested but none of the pictures work, can you try again? Thankyou
R35 Section manager
Pictures are certainly there
Thanks for the reply but just noticed there for R32 not 33
If these are the Alcon advantage extreme front kit (which they look like and have the same 365mm discs), the R32, R33 and R34 kits are all exactly the same. There is a slight modification to the carrier needed for BOTH R32 and R33 (direct bolt on to R34).
Discussion Starter · #13 ·
Is there pads with them ?
No,
you buy the pads separately - they aren’t included as they tend to be a preference thing depending on what you’ll be doing with the car. I brought the kit from Sumo Power so they’ll have pad options to suit your needs.
Cheers,
Brian.
You reckon these any good ? I’m updating the brembo Enzo kit on the 34 & looked at these
£5k for the upgrade I think but brembo similar ?
1 - 16 of 16 Posts
