JDM Auto Link is the official appointed authorized dealer for NITTO Performance Engineering. NITTO is synonymous with producing quality race proven parts for Nissan, Toyota, Honda, Mitsubishi, Subaru and Ford.
Below are what is offered by NITTO. Do email us at [email protected] for pricing and delivery to your location. We will be happy to field technical enquiries as well.
Looking forward to hear from you with regards to your NITTO needs.
Thank you.
EJ
CONRODS
NISSAN
RB25/26H-BEAM
RB25/26 I-BEAM
RB30 H-BEAM
RB30 I-BEAM (21MM & 22MM PIN AVAILABLE)
SR20 H-BEAM
SR20 I-BEAM
VR38 I-BEAM (WITH CUSTOM AGE 625+ BOLTS)
VQ35 I-BEAM
SUBARU
EJ25 H-BEAM
EJ25 I-BEAM
TOYOTA
2JZ I-BEAM
MITSUBISHI
4G63 H-BEAM
4G63 I-BEAM
4B11 H-BEAM
4B11 I-BEAM
FORD
BARRA 4L I-BEAM
STROKER KITS
ISSAN
RB26 2.7L STROKER KIT (I-BEAM RODS)
RB30 3.2L STROKER KIT (I-BEAM RODS)
SR20 2.2L STROKER KIT (I-BEAM RODS)
SR20 2.2L STROKER KIT (H-BEAM RODS)
TB48 5.2L STROKER KIT (I-BEAM RODS)
SUBARU
EJ20 2.2L STROKER KIT (I-BEAM RODS)
EJ20 2.2L STROKER KIT (H-BEAM RODS)
MITSUBISHI
4G63 2.2L OR 2.3L STROKER KIT (I-BEAM RODS)
4G63 2.2L OR 2.3L STROKER KIT (H-BEAM RODS)
4B11 2.2L STROKER KIT (I-BEAM RODS)
4B11 2.2L STROKER KIT (H-BEAM RODS)
TOYOTA
1FZ-FE 4.8L STROKER KIT (I-BEAM RODS)
2JZ 3.4L STROKER KIT (I-BEAM RODS)
OIL PUMPS & CRANK COLLAR
NISSAN
RB20 / RB25 / RB26 / RB30
SR20
COLLAR FOR R32 GTR & ALL GTS-T APPLICATIONS
ROCKER STOPPERS
NISSAN
SR20
DRAG METAL HEAD GASKETS
NISSAN
SR20 1.2MM / 88MM BORE
SR20 1.5MM / 88MM BORE
SR20 1.8MM / 88MM BORE
RB26 / RB30 1.2MM / 88MM BORE
RB26 / RB30 1.5MM / 88MM BORE
RB26 / RB30 1.8MM / 88MM BORE
RB25 1.2MM / 88MM BORE
RB25 1.5MM / 88MM BORE
RB25 1.8MM / 88MM BORE
MITSUBISHI
4G63 1.0MM / 86MM BORE
4G63 1.3MM / 86MM BORE
4G63 1.6MM / 86MM BORE
METAL GASKET KITS
NISSAN
RB26 ENGINE GASKET KIT
SR20 ENGINE GASKET KIT
MITSUBISHI
4G63 ENGINE GASKET KIT
FULL GASKET KITS (DBS HEAD GASKET & ENGINE GASKET KIT)
NISSAN
RB26 FULL GASKET KIT (INC METAL TB AND EXH KIT)
SR20 FULL GASKET KIT
MITSUBISHI
4G63 FULL GASKET KIT
PISTONS (ALL INCLUDE UPGRADE PINS AND RINGS)
NISSAN
RB26 DETT - 86.5MM / +0.020"
RB26 DETT - 87.0MM / +0.040"
RB25 DET - 86.5MM / +0.020"
RB25 DET - 87.0MM / +0.040"
SR20 DET - 86.5MM / +0.020"
SR20 DET - 87.0MM / +0.040"
RB30 DET - 86.5MM / +0.020" (SOHC & DOHC AVAILABLE)
SUBARU
EJ20T - 92.5MM / +0.020"
EJ25T - 100.0MM / +0.020" (SUIT 130.5MM ROD)
EJ25T - 100.0MM / +0.020" (SUIT 131.6MM ROD)
MITSUBISHI
4G63T - 85.5MM / +0.020" (22MM PIN - SUIT EVO 4-9 ROD)
4G63T - 86.0MM / +0.040" (22MM PIN - SUIT EVO 4-9 ROD)
4B11T - 85.5MM / +0.020"
TOYOTA
2JZ-GTE - 86.5MM / +0.020"
2JZ-GTE - 87.0MM / +0.040"
FORD
BARRA 4L - 92.5MM / +0.010"
CAM GEARS
NISSAN
RB20 / RB25 / RB26 ADJUSTABLE CAM GEAR
SR20 ADJUSTABLE CAM GEAR
MITSUBISHI
4G63 ADJUSTABLE CAM GEAR
TOYOTA
2JZE ADJUSTABLE CAM GEAR
CLEAR CAM COVER
NISSAN
RB26 CLEAR CAM COVER
MITSUBISHI
4G63 CLEAR CAM COVER
VALVES
NISSAN
RB20 / RB25 / RB26 VALVES
SR20
MITSUBISHI
4G63
TOYOTA
2JZE
FORD
BARRA 4L
SUBARU
EJ20 / EJ25
CRANKSHAFTS
NISSAN
RB26 STANDARD STROKE SUIT 2.6L 73.7MM STROKE
RB26 LONG STROKE SUIT 2.7L 75.7MM STROKE
RB30 LONG STROKE SUIT 3.2L 90.0MM STROKE
SR20 STANDARD STROKE SUIT 2.0L 86.0MM STROKE
SR20 LONG STROKE SUIT 2.2L 91.0MM STROKE
VQ35DE LONG STROKE SUIT 4.1L 86.4MM STROKE
VQ35HR LONG STROKE SUIT 4.1L 86.4MM STROKE
VR38 LONG STROKE
TB48 LONG STROKE SUIT 5.2L 108.0MM STROKE
MITSUBISHI
4G63 STANDARD STROKE SUIT 2.0L (EVO4-9)
4G63 LONG STROKE SUIT 2.3L (EVO4-9)
4B11 LONG STROKE
TOYOTA
2JZ LONG STROKE SUIT 3.4L 94.0MM STROKE
1FZFE LONG STROKE SUIT 4.8L 101.00MM STROKE
SUBARU
EJ20 LONG STROKE SUIT 2.2L 79.0MM STROKE
EJ25 STANDARD STROKE SUIT 2.5L 79.0MM STROKE
EJ25 LONG STROKE SUIT 2.7L 83.0MM STROKE
HONDA
B SERIES LONG STROKE 92.0MM
B SERIES LONG STROKE 95.0MM
F22C LONG STROKE SUIT UP TO 2.5L 97.0MM STROKE
H22 LONG STROKE SUIT UP TO 2.5L 100.0MM STROKE
K20 LONG STROKE SUIT UP TO 2.4L 92.0MM STROKE
K24 LONG STROKE SUIT UP TO 2.6L102.0MM STROKE
