1 - 9 of 9 Posts
I,ve just received an Aluminium Radiator for the R32 GTR
The temp sensor at the bottom corner of the original radiator doesnt fit the new radiator hole!
think they come in 2 sizes 10mm and 15mm
Is the 10mm for the R32 GTST?
Anyone know if another car is the same? e.g ive read that a honda civic is the same but what years etc?
Same problem mate! Its fine at the moment without the aux fan but I'll need to fix it for the summer.. Did you get the shroud back on?
Was it a japspeed radiator?
Owner of the MSNSPS
Owner of the MSNSPS
My lower shroud fitted fine:thumbsup:
Did your's (the rad) look the same as mine? I had to mod the shroud a fair bit before it would even sit ontop. I suspect that the rad is actually for a different car (maybe GTS or R33). Doesn't really matter as it's perhaps twice the capacity of the OEM item and once fitted the differences are irrelevant.
Would have been nice not to need to re=tap for the temp sensor mind.
Just if anyones interested the Honda fan switch (not coolant temp switch) does fit and seems to operate at the correct temperature. I've spliced it into existing loom but not tested it out yet as cars in bits!
1 - 9 of 9 Posts
