just not keen. Splitter is very close to speed bumps etc as it is.Whys that? 15mm and 20mm and springs look awesome ??
Eibachs are fine for this and stand up well on track...Iain fits these because of the proven strength of them...however the cheap ones around I agree are a very dangerous fitment.Because that is what is it there for!
Stress, strain on a car with immense cornering forces![]()
From memory 10 on front and 15 on rearWhats size do you run henry 145
Except that running lower offset wheels is also bad for the wheel bearings! Just because it's the same as another bad thing doesn't make it ok.this issue with extra load on the wheel bearings is negligible as its no different than running wheels with lower offsets.
LOL, and the time it does will be too late ! Why risk it ?I have been using H&R 15 mm spacers front and rear, for 2 years ( 25 track events ) no any sign of cracks.
Hit the nail on the head.Except that running lower offset wheels is also bad for the wheel bearings! Just because it's the same as another bad thing doesn't make it ok.
What risk ? If everything is checked after each track day, no risk if you use good quality spacers. Much better handling, better grip.LOL, and the time it does will be too late ! Why risk it ?
Yeah, but it might not be the nail that is being hit on the head if your wheel fly’s off at 100mph !!!!!Hit the nail on the head.
Both have pro's and cons. it's the end users choice.
