Not sure if will work,
says to run on 6/8 cyls with 3 or 4 coilpacks.
RB26DETT has 1 coilpack per cylinder.
Not sure if this ignition system uses alternative coilpacks.
okay thanks for the info. i have emailed MSD to see what they say. ill post what i find out.
Its a cool unit with lots of built in features.
Discussion Starter #4
According to MSD, this system cannot be used on a Skyline as a Skyline uses a ignition module on each coil. they will be making a system for the Skylines in the near future though.
Here is a 6 cylinder CDI set-up fitted to a Skyline, it uses two three output CDI's
Switchable power output between 105 mj and 150mj.
