Does anyone know how to remove the old rubber window strip as in pics. Then how to fit the new strip.
Have just got a replacement from Japan but cannot work out how to replace it.
http://www.paullarge.com/images/rubber_strip_GTR.jpg
http://www.paullarge.com/images/rubber_strip_GTR2.jpg
Paul
ps How on earth do you post a pic directly into this forum ?????
Fixed the URL to get the pics -soz
Hi Paul that trim is pressed into the door, get some trim tools and start with the aft edge of the window seal and gently press on the seal in a upward direction and you will get movement and work along to the front of the seal
On a 32 there is a small screw at the back of the door.
Not sure if you have that on 33/34.
Easier to remove if you lower the window.
Discussion Starter #4
Sorted by Nissan in the end. The car went in to have some paintwork under warranty and they fitted it for me. They had to remove the door card apparently .. ! - Anyway thanks to all ... P
