Just searched arround the forum but I couldn't find any major feedback about this ECU. I recently found this ECU available for our cars as well (never knew about this ECU in the past) and seems like $360 cheaper than my other alternative which is the Haltech Pro Plug In.
I'm guessing it has knock control (it has a port to plug ear headset to hear the knock while tunning which rocks, just like the Motec ECUs I think), e85 compatible etc etc.
As I understand it has "self tunning" by AFR target value like the Haltech I think. Not sure if compatible with the stock MAFs but I guess it does. 4 BAR MAP build in which is perfect.
Anyways, there are any members here running it? If so, any advise positive/negative commentsa bout ti? Tuning software is frienddly/good?
LINK HERE (no affiliation)
Features
  • Multiple tuning modes including Volumetric Efficiency for accurate & easy tuning.
  • Advanced Adaptive Fuel & Ignition Control including 100% configurable tolerances, loop gains, & conditions for automated AFR, IDLE, & Transient Throttle Control( Closed Loop Self Tuning).
  • Internal 4 bar MAP sensor for engines running as high as 40 psi of boost.
  • Advanced Engine Protection Features- definable rev limiters for engine lean out, low oil, fuel or auxiliary pressures, etc.
  • Eight Auxiliary Outputs (four high current outputs & three PWM capable) for boost control, nitrous control, etc.
  • Traction & Launch Control configuration.
  • Dual closed-loop variable valve timing (VVT) channels.
  • Integrated 3.5mm headphone jack for real-time listening to knock
  • E85 Flex Fuel Control for maintaining accurate injection rates utilizing real-time ethanol content monitoring. (Requires Flex Fuel Sensor like GM or Zeitronix)
  • Built in Boost Control Software including Boost by Gear using OEM transmission sensors
  • Spare 0-5v analogue input, one spare aux output, 3 spare digital inputs; multiple temp sensors inputs require Innovative SSI box
  • Water/Alcohol Injection Control
  • Integrated Diagnostic LED's for easy visual confirmation of proper Trigger, Fuel Injection, & Ignition System operation.
  • Instant Dual MAP Switching capability for street & track vehicles!
  • User Configurable Sensors - compatible with any and all senors
  • Serial Port connection for zero soldering wideband o2 sensor installation
  • Race Dash Integration via Serial Output.
  • Innovative Wideband/TC-4/SSI-4 Daisy Chain Compatible via serial connection.
  • PLX Multi Display Gauge & Android App Compatible for real-time engine parameter display.
  • Easy to use WARI tuning software with USB connection to PC's running Windows XP, Vista, 7, & 8.
  • Easy Datalogging with no additional hardware/software.
  • Excellent direct and community technical support.
  • 12 Month Warranty
  • If using a Automatic transmission you must use a wire in model E420D, E440D, or E1280S in series with the OEM ecu for proper automatic transmissoin control.
  • MAP based tuning for single turbo models, combined MAP/TPS for GTR models
  • Variable valve timing supported for R33 RB25DET
  • Scaled TPS output for R33 and R34 GTR (on R33 ECU)
  • Wasted spark ignition configuration
  • Semi sequential injection configuration.
  • Works with the OEM trigger, no CAS disk swap required.
Looks like a Link g4 at a glance. Any reason for choosing only this or the Haltech?
I don't have really any solid argument to choose the Adaptronic over the Haltech Pro plug in as I didn't invstigate deeply the features of the Adaptronic but at first glance it seems to have some cool stuff among the head seat to listen knock (which I did adapt from our mechanic shop the tool to hear noises from the chasis in my ex BMW e30 turbo converted to tune in on the road and was great tool to have as knock sense), build in 4 BAR map sensor if I want go more boost later, seems to have great support at least over the forums, also it does cost less over the Haltech.
A friend of mine will tune the ECU I chose but he has more experiencie with Haltech (had some seminars in the states with that) but he told me he did tune once a car that had Adaptronic not sure what model.
Logic tell me to go with Haltech because of the tuner it's more familiar with it....
Haltech Pro plug IN R33
Features:
• Direct plug and play replacement of the OEM ECU, no re-wiring necessary.
• Uses the cars factory sensors
• Supports R32 GT-R twin MAF sensors
• Supports Sequential Injection (peak and hold) and Direct fire ignition
• Windows 2000, XP, Vista, Windows 7 compatible software
• Real time programming, instant hesitation free adjustment while engine is running
• Fully user definable 32 x 32 mapping
• Tuning via Volumetric Efficiency (VE), Injection time or Lambda Correction (MAF)
• OBD II Code Storing & Malfunction Indicator Light (MIL) Control * * (Access through laptop
only )
• Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
• Wideband “auto tuning” using user definable target AFR table
• USB and CAN Communication Port
Factory Outputs:
• 6 x Fuel Injector outputs
• 6 x Ignition outputs
• Tacho, Boost Control, AC Clutch Relay, Idle Control
• Thermo Fan, Check Engine Light, Fuel Pump (Variable Speed)
• N-VCT ( Nissan Variable CAM Timing Control)
Factory Inputs:
• MAF sensors, Throttle Position Sensor, Oxygen sensors,
• Coolant Temperature sensor, Vehicle Speed Sensor,
• Air Temperature sensor.
Expansion I/O*:
• 2 x Analogue Voltage inputs
• 2 x Analogue Temperature inputs
• 4 x Digital pulsed outputs
*Optional auxiliary harness required to be purchased Haltech Part # HT040003
Functions:
• Closed Loop O2 Control
• Decel Cut Over Boost Rev Limiter
• Closed & Open Loop Boost Control
• Gear Setup
• ACF On Base Tables
• Transient Throttle Enhance
Correction Tables: Fuel Ignition Boost:
• Cranking
• Air Temp Target Correction
• Coolant Temperature Correction
• Map Correction
• Zero Throttle Gear Correction
• Cylinder Trim
• TPS Correction
• Generic Correction 1
• Generic Correction 2
• Gear Correction
• Post Start
• Air Temp Duty Correction
• Post Start
Miscellaneous:
• Data Logging: 448Kb of onboard data logging,
Storage for approx 40 minutes at 10 logs per seconds, 6 channels of data
• Max 20 channels logging capability
• Tune can be password protected in software
• Rugged anodized aluminum casing
Power Requirements:
Source: 8.6 to 16.5 Volts DC
Consumption: 530mA @ 12Volts DC
Now I also found that for the R33 GT-R or the Skylines there are two options of ECU an done is made for more than 500 HP (I gues sit has more resolution for the fuel injctors control and some other options)
R32-R34 Skyline ECU | Adaptronic
