Shouldnt it just be PnP with a Apexi PFC in a R34GTR V-spec II JDM version ?
As it is now it will not start when the Apexi PFC is in the car but when the oem ecu is installed it works. Can it be the immobiliser ? thought that this was only a problem on the UK spec R34 GTR's due to a differet ecu pin config.. All help much appreciated .
hi
you may need to turn off the boost control function.
when theat function is on and you don't have the boost controler for the pfc it won't allow you to start the engine
hope this helps
mark
