Anyone got one of these fitted to their 32?
A'PEXi U.S.A. - Products: Electronics
I have one ordered from Nengun. They mention certain cars may also need the harness too, but I can't find mention if the 32 needs one. I was looking on some other sites, and using New Era as an example, they also stock it and say it's compatible with the 32, and it doesn't mention the harness.
I want to make sure so I can have everything ready to get it fitted.
The harness is needed if you want to 'plug and play' without cutting into the ignition loom. Mine was hard wired as part of the alarm fit so didn't need one.
yep, the harness is definitely necessary, but you still need to send a wire to the handbrake. Don't bother sending the O2 sensor wires to the ECU loom - it won't work with R32 titania O2 sensors and you'll just get spurious A/F readings.
