As above,
Are the GTS etc Headlights the same as a GTR?
I know there are different colour options such as clear or smoked and Xenon but are the sizes and fittings all the same??
Following EJH#25
The units are the same, but the GTR headlights are mounted with a spacer which is the only difference AFAIK.
Also, the GTR lamps only have a singular in-board plastic mounting, where as the others have two!
you can clearly see tho that the GTR lamps are from the same mould, only the lower fixing has been blanked off in the mould.
sloathy said:
Cheers chaps,
So would a GTS etc light unit fit a GTR?
theoretically yes, but they need to be mounted more forward on a GTR so i dont know if you have the spacer?
