I've just been surprised by someone who has a fairly stock UK Supra TT and reckons for about £5500 can get it to over 700rwhp with the following bits on a car that is currently stock apart from the exhaust:
1) Fuel kit (fuel rail, injectors, twin fuel pumps, fuel pressure regulators etc.)
2) FMIC
3) Exhaust already been done
4) Greddy emanage ecu piggyback
5) Oil catch tank
6) A bigger turbo
Turbo wise, he has quoted this:
Is that really right?
2) FMIC
5) Oil catch tank
6) A bigger turbo
I will be stunned if that's all he needs to spend and do to get a car with that much power, seeing as the going rate to get a Skyline GTR up to that much power seems to be in the region of £30K.If and only if you are looking for the best quality turbo kit to install on your Supra, stop here, you've found it. We at MVP have 6 years of experience working with virtually every turbo kit on the market and it is our firm conclusion that PHR consistently manufacturers the highest quality parts available to the public. Their turbos also tend to spool quicker and make more power than the others. We suspect this is because they custom build their own turbos using Garrett-manufactured parts (same as HKS) instead of the off-the-shelf Precision Turbos used by most of PHR's competitors. PHR kits are known for having extremely quick turbo spool yet producing as much power as more sluggish turbos like the T78 & T04R.
This is the exact same kit as the Stage 2, except for the turbo. This Stage 2+ (GT67) was originally tested by us here at MVP. On one of our Supras it turned just under 700rwhp on a bone stock motor. We added an intake manifold & achieved 728rwhp. But its not the power that makes this turbo special, its the power you get for the small amount of lag. This turbo hit full boost at 4,300 RPM's, only 100 RPM's after the Stage 2, yet was capable of another 40rwhp on a stock motor. This turbo, in our opinion, is the ultimate street turbo. We've driven almost every turbo available on the market from the T78 to the SP66 to the T51R, and this is the best turbo for the street. It is the perfect combination of power & *TRUE* daily driveability.
