1 - 10 of 10 Posts
Yup, that looks like the set I had on my old engine.
Having said that, for the effort of installing them in the engine, and the price now for a good set of rods, I'd be putting aftermarket I-Beams in.
But didn't your engine get rod knock? In that case at least one of your rods stands a good chance of being ****ed.
If new bolts are not fitted properly you can make the big ends out of round and the rod will be junk.
Also to ensure the rods are 100% ok they need crack testing then new rod bolts installing and then sending to have the big ends recircled.
After you have done all that so you have 100% confidence in reusing the rods they have been more agro cost more and are still not as strong as a new set of forged rods.
Yes no 6 rod is fubard but got a new rod it was only no6 that span as usual with these bloody engines
Tbh I've been thinking about fully forging the block and looking into getting rods the prices aren't that bad I mean £300-350 for a set ain't bad tbh and those are Manley rods too
Manleys are the same forgings as Eagle rods, from China, they are finished at manleys facility if i remember right.
Not a bad rod, probably the same rod forgings that Tomei use ;)
Look in to their Turbo Tuff rods tho, depending what power levels you are going for.
Discussion Starter · #8 ·
Ok cheers for the info I'm only planning on 550 crank hp no more than 1.4 bar likely less its a road car but I'm after response over power numbers so even if it don't make 550 as long as it shifts like a gudun I'm happy
I have eagle in mine. Pretty much same as Manley.
Had no probs with them in 8000 miles and as you say for £350 you can't go wrong really.
Got to be a better option than messing around with standard rods with an unknown history.
Just don't want to see a "Third time lucky" engine rebuild thread mate.
Discussion Starter · #10 ·
Yeah I know what you mean its kinda counter productive so I'm best going forged rods me thinks
1 - 10 of 10 Posts
