1 - 7 of 7 Posts
May be panicking about nothing but I've just pulled into work with windows down and as I turned around in the car park I heard a nasty metallic scrapping sound coming from the frontend. Not clicking wheels.
Just had a spirited drive into work in full R mode so car was hot.
any ideas please.
any ideas please.
Have you got aftermarket discs with spacers on the callipers?
I have heard of discs expanding on the diameter with heat and rubbing on the calliper body. As the disc cools / shrinks the issue goes away.
Just a thought. Chech the paint on the calliper for signs of rubbing.
Satan.
I'm running Alcon 400mm fronts. Only seems to be when the car is hot and only when I'm on 3/4 lock.
thanks for the hint, I'll pop the wheels off at the weekend and take a look.
initially [email protected]! T myself thinking it may be diff related.
1 - 7 of 7 Posts
