1 - 8 of 8 Posts
Anybody have a picture of the Air bleed connecter under the dash?
I have a R32 GTR.
Thanks in advance for any help on this.
Robb
Dear Robb,
I wish I could help you and knew the answer, but I have a friend who works at the Nismo Paddock in Chiba in Tokyo and I will ask him. Good Luck. By the way, did you Bring your GTR in through Motorex?
R-33Vspec Karma
Sorry Robb,
I cant seem to get a hold of my friend takeshi for you. I will keep trying but I think he may be on vacation. When I do get it, I will PM you.
Chris
I am assuming this is to bleed the Attessa system. If so, R33 has a plug near the fuses and R32 should be the same. Unplug it and turn the ignition to on position before opening the bleed screw at the back of the transfer case. Make sure you have sufficient fluid in the reservoir.
1 - 8 of 8 Posts
