Is anyone up to speed on problems with this system? 36 is E-TS fail safe solenoid and circuit.
Intermittent fault, ABS and 4wd both come on, switch off ignition and codes clear and warning lights off. I removed the ecu connector and replaced just in case of a bad connection. Anyone else had this? Fluid in the reservoir is correct.
