Hi all,
Need abit of help and cant seem to find an answer while searching up info.
I had my GTR dynoed a week ago and only rear wheels would spin... The front wheels wouldnt spin so i believe the 4wd system isnt working.
I've done the common diagnostics so far: the 4wd fuse is there and not blown, the 4wd light does come on during electrics on mode then turns off once car is started, the torque meter does work when you accelerate, there is no flashes from the Attessa ecu in the boot and the attessa pump does prime.
Does anyone have any idea what it might be?
My mate says the system might just need re-bled again or worse case the clutch plates are worn on transfer case.
Any suggestions are greatly appreciated.
