Quick question, if I'm sticking in a new clutch pack and replacing all the fluids ..how much atf do I need??
cheers
When I find out that hero we all know and love ' Oilman ' will be getting some more business off me..
i would measure what comes out and then replace with the same amount. That way you know what was in there before and wont need to mess around while refilling.
Hi cleethorpes,
I remember doing this.
Its not a drain and fill unit.
The procedure is in the free pdf manual.
From memory I put the car on a ramp, ran it and there is a relay you bridge that runs the atessa pump constantly.
This enables it to drain the reservoir. Keep topping this up as it bleeds through until clean clear fluid comes out , close bleed nipple and top up reservoir. Job done.
cheers cokey
