41 - 60 of 77 Posts
Coil lead is a constant source of problems. These are simply the best and in the same time cheapest solution if u have under 1000hp, and u can count those here on your hand's fingers, no need for toes :):):):):):)
Coil leads allow the coil to be kept cool. Coil leads stop the direct heat transfer from the engine ( the reason why a spring is used ) .Direct copper spring clip connection gives a better spark but the heat is greater. Coil on plug saves money. HT leads never give a problem in my opinion if they are decent quality. Most of the issues on the RB are roasted coils or tracking over the removable boots. The coil itsself is good. There are better coils out there so for me I run with the coil cover off most of the time so remote or coil on plug no difference for me.
hi, no problem.
sadly for some reason i can't post any pic's to show you what has to be changed:bawling:so will have to write it all and hope you will understand it;)
here goes ; you need to remove the igniter pack from the top of the engine and make up a plug/connecter to join the wires etc.
on the top of the igniter it has numbers (1'2'3'4'5'6'g ) on it on the in and out side showing where each wire goes in each plug.
now join the wires 1 to 1, 2 to2, 3 to 3, 4 to 4, 5 to 5, 6 to 6 & g to g
be very careful to get them in the correct order ( they are all the same colour,pink, eccept for the ground which is black)
next you need to change the coil pac plugs from s1(brown) to s2(grey) type
when changing these the position of some of the wires need to be changed
on the coil pac's you will see some markings, on the s1 will be -,+,E and on the s2 will be +,-,IB.
on s1 - is the ecu trigger signal, + is the 12volts and E is the ground/earth to chassi.
on the s2 + is 12volts, - is ground/earth and IB is the ecu trigger signal.
just move the wires to the new positions you are finished
hope this helps and you understand what i have written
mark
So found this info for removing the igniter pack is it really that simple? also with these Audi coils so you just run an extra earth ? ( i.e. 3 pin vs 4 pin )
As long as you get a good -ve and + ve to the coils where they draw the power, then the trigger ( the 5v signal ) is connected to each coil then all is ok. Its a simple conversion. Some coils have a separate ground for the trigger signal to keep the signal clean. Some coils that include the igniter have additional capacitor circuit that allows additional current and aid the spark a sort of CDI.
I tried a number of aftermarket options and finally chose a twin box M&W CDI set-up with Mercury coils and Magnecore leads
Provides Spark energy150 millijoules.
Really made the engine run cleanly delivering such a high energy spark at high boost and high RPM.
Going to be putting it up for sale in the next couple of weeks.
Hugh
Cool well might have sorted what coils i might use...
Just wanted to ask people this conversion to remove the igniter pack will not harm my ECU at all~?
No it wont harm the ECU, but fitting after market coils to a standard ECU is not the best idea, as each type of coil has a charge time and a lag. This cant be adjusted in the standard ECU. Most wanting to run different coils have after market ECU's
We use the AEM coil wit good results. yes a plug lead can cause hassle but Magnecor 8mm leads work very well.
Running the coil out of the cam valley helps them a lot due to running a lot cooler.
The AEM coils require good direct 12 volt supply via relay you can remove the amplifier pack as well.
They make a huge spark , we seen these jump the spark through cheap plug leads rubber boots on the dyno with Jeff Ludgates Drag car when we was waiting for the Magnecor leads to arrive.
please dont hold the plug lead/coil when the car is running it will give you a might shock.
I own a S4 Audi had the coils changed twice under warranty. they always change all 8 as well.
Lots of builds using VAG coils and going over 1000hp without problems.
The best solution is of course CDI but it's 5 times the price.
CDI is fast enough to spark several times before the piston reaches "top dead centre" at lower RPM.
The M&W CDI set-up I used would spark over a huge gap.
It was so powerful, absolute cleanliness was required on the outside of the plugs to ensure the spark did not arc down the outside of the plug.
A powerful spark over a large gap ensures the accurate timing of combustion at high RPM, allowing your engine to run cleanly at high boost.
Personally, having made a big investment in my engine, I wanted it to run cleanly and stay together without the risk of damaging the engine.
Ignition systems can never be too good. Have seen many engines fail because of weak ignition systems..
41 - 60 of 77 Posts
