Can anyone think of a situation where you would want to flick from auto to manual but not actually change gear? Me neither! But even if you can, is there any reason not to just use the main gear lever to do so?
I would like to change the default behavior of the paddles so that when flicked while in auto-mode, they not only switch to manual-mode but they also perform the gear change.... why would you not?
Does anyone know if this can be done using Consult-III or AccessPORT ?
