Autronic SM2 V1.94 Purchased from Mark Shead
Loom is currently made for a subaru and easily altered to fit anything (There's plenty of wire to solder to, or make a loom adaptor with, those that are short are around 5" Long, but the crimp connectors are easily removable from the plastic shell if you wanted to replace the wires with all new ones.
Im sure Mark can change the chip version if required.
£850 - I can also arrange fitting and mapping at an extra cost if required.
Techedge wideband with homemade convertor to input wideband signal into ecu, never calibrated properly but at a glance looked pretty spot on with the PLM in the car, bit hard to compare to the laptop screen and the plm though whilst driving!
£140 - Including NTK UEGO sensor.
[email protected]
David
[email protected]
David
