Status
Not open for further replies.
1 - 6 of 6 Posts
Are you having problems with your R35 AV unit?
Draining the battery?
Crackle on your speakers?
Lost all your audio?
I am now an authorised agent for the official Nissan/Clarion exchange programme so I can swap your faulty unit with a fully working unit, direct from Clarion with 12 months warranty.
Typically this fault is found with the earlier non-nav 2009 units but I've seen it many times on the navigation units up to 2013 and the exchange service is available on both systems.
If you are having problems, drop me a PM and I'll let you know the options.
Andy
Hi mate I can't pm yet , my head unit has got a problem the iPod and media doesn't work cd and radio work fine tho
Hi sir can this be just a connection issie? Maybe it was installed wrong?
Sent from my iPhone using Tapatalk Pro
U1000 I've heard might be earthing fault, maybe loose ground. Not seen the U1300 but there is a AV unit check by going into the secret menu.
Google "GTR secret menu" and see how to get in there and then you can check the logs and also do a diagnostic check on the AV system.
Andy
Replaced my head unit with a dba upgrade and problem solved. Thanks for the reply guys
1 - 6 of 6 Posts
Status
