1 - 6 of 6 Posts
Banned
I have connected the speed output wire from the AVCR to the speed signal wire on my R32 and the speed displayed on the AVCR is wrong, at 40KPH on the speedo its reading about 19KPH :confused:
What ecu are you using? and have you made sure you are looking at the RB26 R32 wiring and not the RB26 R33?
Double check to make sure you have the output going to the right wire.
Banned
Only a std 32 ecu. I have tripple checked all wiring and its still no good:confused: BTW I dont have any speedo convertors or anythign like that should i just add...
Banned
Thanks scoob! btw what is the best setting for boost? absolute1 or 2 or relative 1 or 2? not sure which to select.
Banned
Discussion Starter #6
1 - 6 of 6 Posts
