Started to get a banging from the back end (oo-er
) so had a peek under the back bumper. The backbox is suspended by two rubber hoops that hang off a metal bracket (with pins sticking out each side) which is bolted to the chassis rail.
It looks like the pin on the right hand side of this bracket has corroded and snapped off, so the other pin on the left holds the exhaust but it's pulling to the left and clonking the inner edge of the bumper.
I've highlighted the bit in red:
The bracket seems removable by unfastening a nut or two (can anyone confirm this), so if that's the case does anyone know where I can get a replacement from?
Cheers,
Jim
Cheers,
Jim
