1 - 10 of 10 Posts
Does anyone know how to disconnect this pain in the a55!
The ball joint is connected to the hub by a bolt. I have taken off the nut but the bolt won't shift. At the end of the bolt there is a hole (dodgy illustration enclosed!) - is this hole for a special tool to unscrew the bolt from the hub?
Hopefully, anyone who has ever had to remove a wheel hub or change a lower arm will have had to overcome this dilemna and can help me!
GTS 2.5t so rear wheel drive only.
Andrew
:smokin:
might not be of any help but
might just be a push fit so needs a rubber hammer to tap it out
and the hole is for a split pin !!
iam not a 100 % reliable so letts wait for the guys who know !
a rubber hammer some wd40 and a srewdriver and anything will come off!
Its locked with a split pin, and is also held by a taiper. Remove the split pin, and un-screw the nut - DON'T try and knock the joint out until you get the nut on-to the last remainding threads, or else the bolt will just turn round, and you won't be able to unscrew the nut.
If the balljoint is running round, an air-impact rench will remove it.
Jason.
does this meen iam right?:)
Jason,
Do you mean the ball joint bolt should turn within the hub? Mine doesn't seem to move up or down or rotate or unscrew! What am I doing wrong???
Am I supposed to take the pin out, take the nut off and then put the pin back in and put the nut back on? Will that cause the bolt to unscrew?
I am totally confused!
Just one more question - does the balljoint pop out like a dislocated shoulder joint?
Andrew
:smokin:
was that meant to be straight
kerbs arnt funny when they do that are they!:)
1 - 10 of 10 Posts
