Bee r power builder
BeeR power builder including postage to Europe Yen: 28,000
Information and instructions below.
Bee Racing Rev Limiter:
The unique REV LIMITER from Power Builder Bee Racing is a device where a driver can use to prevent a vehicle's engine from being over rev. All parameter adjustments on this device can be made on the fly from the driver's seat. This REV LIMITER is achieved by cutting off the ignition at a preset RPM limit, and by re-routing a fuel dump. An aural feedback of back fire popping sound from the exhaust muffler is the result followed by a fantastic visual of fire coming out from the exhaust muffler tip. This aural & visual feedback are very similar to those experienced in the fully race-tuned race cars .
The rev limiter in the vehicle is controlled by the factory ECU by instructing the fuel pump to immediately stop the fuel supply to the engine. Such immediate forced fuel cut is not advisable if it happens frequently as it has damaging effects to the engine in the long run. On the other hand, with Power Builder Bee Racing's REV LIMITER, it actually cut off the engine ignition without stopping the fuel supply to the engine. With this function, over rev limit damage to the engine is prevented, and is a safer way in the long run when the engine is over revved past it recommended RPM limits.
The visual effect of having fire spitting out from the exhaust muffler every time there is a rev cut when the REV LIMITER is installed is not guaranteed by Bee Racing. This is due to the fact that fire would only result during high engine revving, and when the exhaust muffler is warm up, and also when the vehicle exhaust system is without a catalytic converter. Basically, the unrestricted vaporized fuel supply when ignition is cut off is lighted off when it mixes with the air from the engine air intake in the hot exhaust system. The hot temperature from the exhaust system is the catalyst that ignites the air-fuel combination in the absence of the ignition sparks.
Wire set up:
R E D - IG12V /Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
BLACK - Connect this wire to theh vehicle's chassis' earth/ground contact, or the the vehicle's battery earth/ground terminal.
YELLOW - This wire is for the RPM signal. Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
GREEN - This wire is for the ignition signal. Please refer to the wiring diagram supplied in the installation manual, and connect it to the designated vehicle's ECU.
WHITE - This wire is for the side brake switch signal. REV-1 works without connecting it.
SET-UP and SWITCH
REV-1: To set up standard RPM.
REV-2: The white wire connection set up the RPM readings that corresponds to the side brake switch signal. It works using an external switch. It switches off the engine by inputting a negative signal.
GAIN: Controls the engine RPM cut off setting. For example, o is off, and 1 ~ F is the adjustment range. The standard initial setting is 6.
Wire set up:
SET-UP and SWITCH
