1 - 8 of 8 Posts
This was made for my R34gtr and has only been used on the dyno i'm sure it will flow as much power as you want:thumbsup:
The down pipe is 100mm diameter stainless steel and has been coated in the best thermal barrier you can get as used on formula 1 cars and many other pro motorsport cars Zircotec high temperature coatings, ceramic coatings, engine, automotive and motorsport, exhaust manifold and header coatings. you can plumb your waste gate pipe back into the down pipe or use the screemer pipe:D
The exhaust is also made from stainless steel and also starts off in 100mm diameter pipe which then come's out from the silencer in a 180mm X 50mm oval pipe which comes out infront of the rear near side rear wheel.
The system is quite loud around 115db at 5000rpm static test.
£1100 plus delivery
Neil
Cheers mate.
I would have thought this will fit an R32 or R33 to just a couple of measurements would know for sure.
looks and sounds sweet, especially when flaming out the side if the car lol.
Still for sale
Still for sale £1000 plus delivery.
Reduced £900
Discussion Starter · #8 ·
Still for sale £900
Ideal for you drag boys.
1 - 8 of 8 Posts
