Discussion Starter #2
searching back through threads, +12 is what gets mentioned a lot, so if i was to buy wheels with a +30 getting some 18mm Hubcentric spacers would sort it out?
Yep +12 seems to be popular, so yeah an 18mm spacer would do the trick.
I run 20mm Ultralite spacers, bolt on, so no messing with longer studs in your hubs, just need to have the studs supplied pressed into the spacer, local engineers charged me 20 quid to do the set.
Nice bit of kit and cheap too.
