1 - 6 of 6 Posts
Hello guys,
(TYRE SIZE 255/40/17)
Wanting peoples opinions on what tyre to go for. I was first thinking of getting some Toyo R888's which I can get for about £800 and has a medium compound than i was advised by 2 of my mates to go for the Yokohama Advan A048-R which is just over 1k and has a medium-hard compound.
The car will be 50-50 road/track use, so basically looking for the tyre with the most grip , looking for someone that has had a lot of experience with these type of tyres and has some advice for me.
I have a car on Toyo R888s and a car on Federal RSR.
The 888s are a little better on track but I have to say that for the cost I can't fault the RSR.
They seem to clear water better so probably a better road choice.
No experience of the Yokos.
I've had Federal RSRs and A048s on the R32. The Federals are great for the money - but you do have to put up with the tread splice separation issue.
The A048-R is being replaced I think. I got mine very cheap through an MLR group buy. They are very stick when new, the grip is impressive, better than 888s I'm told and I believe it BUT they are soft and wear more quickly than the Federals and the super grip doesn't last very long - I guess this would be worse still on a high power car.
Discussion Starter #4
I’ll be too scared to drive it in the wet to start off with :/ , dry conditions only :p
Yeah it’s just trying to justify paying 300-400 quid extra for tyres, are the tyres that are more expensive really that much better if so then I can justify paying that much extra.
The A048-R should last longer than the R888's I would imagine as they are a harder compound, so A048-R is 50 quid more expensive per tyre that is more sticky and should really last longer.
Maybe I'll just go all in with the A048-R's, better safe than sorry then maybe try cheaper alternatives later on to compare for myself.
Discussion Starter #6
For £800 the 888s are a better bet than the A048s for an R32 imo.
The "medium-hard compond" A048 is what I have, apparently its the same rubber as the medium just a different sidewall, and I hear they don't last as well as the 888s especially on a heavy car.
Really ?!
Fair enough back to R888's then i think, 200 quid saved there :)
thanks for the input guys
1 - 6 of 6 Posts
