You've seen a 4cylinder engine designed originally to develop punchy midrange power fitted with a 900hp+ turbo and surmised that needing a lot of boost to make 800hp is because of the turbo?
If you are going to be making authoritative statements on how a turbo is performing you should look at the compressor maps at least... Or for amusements sake have you pondered what kind of rpm and VE a 2.2 litre would need to spin up 800hp on under 2.5bar in petrol? At a quick glance it looks like on the right engine it should be capable of hitting 800bhp at anything over 1.3bar... Or less depending on the fuel.
whatever the comp maps say that's 2 results now one on a 2.2 and one on an rb30 this side of the pond that have needed a lot of boost to make the numbers, the evo made 707 at 2 bar, the rb30 made 770 at 2 bar im almost certain my gt40 would make 770 at 2 bar on an rb30, im only 60 hp off now with my rb27 at 1.5 bar !
also that evo engine is built by mad and will be built for the task at hand and to get the best from that turbo.
id like to see an engine capable of 800 hp with an efr 9180 at 1.3 bar ....
