Whats everyones opinions on the fastest spooling highest torque making rb30 twin set up.
Im currently finishing up a stroker RB30dett/rb26 head,87mm cp pistons, Brian Crower 90mm stroke crank and rods. 3210cc. tomei typeB pon cams and garrett 28710-10s (a/r64)
I just awaiting my block to come back from the machine shop to start assembling my rb30 for my other33. Im looking for the best twin set up to make fast spooling high torque, high hp. after doing reseach on Fuel quality her in the states im prety much limited to 600whp befor race fuel is needed.
mods are 87mm flat top carillo pistons/ manley rods, nissan N1 oil and water pump, Rips AWD adapter, ported head, 8.38:1 compression, Tomei type a 260/252, tomei 276lph pump and id 1000cc injector.
Im hell bent on using stock mount twins, I want this motor to look stock under the hood
The only stock mount turbo that looks llikr the right one for my goel would be theGarrett 707160-10 Turbo GT2860R -10 .
Can anyone chime in her? I could use some advice. Rob from Rips has already been a great help, But for the twins im still on my quest,
the rpm range for the motor 0-8000rpm.
J
J
