1 - 13 of 13 Posts
whats the best way to grind an rb 26 shim can you do it with agricultural tools such as a bench grinder or maybe a hand file or does it require much more sophisticated machinery ???
Skyline Section Manager
You NEED to use a surface grinder. Eg, proper equipment. the shims are as hard as the file. An angle grinder will just wreck it. They need to be parallel to 0.01mm
Discussion Starter #6
did a google on surface grinders yes specialist equipment indeed not somthing you would buy for one build
Certainly not , although i do have one about a foot from my bench at work .
Although that doesnt help much. :(
Check your local yellow pages for engineering machine shops. :)
Discussion Starter #8
the head is with a machine shop but i was going to take it back and shim it myself to hurry things up because the motherf*****s are holdin up my build for the last month ah well sure ive nothing else to be doing christmas week:mad:
you don't even need to grind the shims at all, as part of a normal freshen up they should machine the valve tip, do a dummy assembly, measure your clearances, move shims around as needed to get as many correct as possible and 'tip' the other valves as needed to get them all correct. Rob
Discussion Starter #10
you see my problem was with the new hks cams the stock shims were too small i didnt have correct measurements so i ordered the biggest size the supplier had on da shelf and will have to grind to suit
Which cams do you have?........ - on the higher lift cams (step 3) they drop the base circle which necessitates the use of thicker buckets.
Discussion Starter #12
there step 2 272deg i guess the base circle is dropped in them a bit aswell but buckets aint required just bigger shims it seems
You need a small surface grinder, best to buy a few thin shims, get measurements for the sizes you need and buy them ready done from either Nissan or someone who has oversize, through hardened, blanks :)
1 - 13 of 13 Posts
