hey guys what alternators do people use on there cars if there runnig lots of pumps and electrical equipment .
im just concerned as i have 2 fuel pumps ,a large stereo, and mr2 electric powersteering that can draw upto 60 amps on its own surely there must be a 160amp or higher upgrade seeing the original one is only 80/90amps i just think my system must be at strain and dont want low voltage to ecu thanks people for info :)
I use a 160amp Infiniti I30 alternator, it works pretty well and bolts straight in.
thanks for the reply did you find you needed to upgrade due to the low amp standard one ? 160 amps sounds plenty im sure other people must have the same problem ?
