1 - 14 of 14 Posts
I there I have an r32 gtr and I am after a set of big front brakes not stupidly expensive but good and also a set of good uprated coil packs as mine are on there way out
Ive got some Brembo F40's with 360mm although from an R33 GTST. Also have the matching rears too. How much you willing to spend?
Like the sound of both of these at the moment I only have 17 inch wheels so not to sure will fit under them how much do both of you want for these
Please do your homework on this. I say this as its not about simply putting on a set of larger brake rotors.
1st off since the roads are sprayed with metal eating salt in the UK I would have a proper look into all of the basics.
Swap out and replace the brake master - use an auto brake booster since its larger and will give you better pedal feel, next get a pedal box -from an s13 UK spec - send it out to have it stiffened and painted. Next Brake masters you will will need to look for an upgraded unit that is slightly larger.
now if you want a set of brembos ok good your on the right track but if you dont have the budget for that A set of high quality rotors with some pads will work - using a 2 peice rotor setup, if you want to keep the stock GT-R 16X8 rims.
Keep in mind if your going for bigger calipers and rotors gotta make sure your rims clear on the inner diameter.
So if your on a budget stick with the stock set up and use all new good and high quality parts.
Discussion Starter · #10 ·
Not really on a budget but st the same time don't want to spend a fortune the wheels I got aren't the standard size I have 17x9 or 9.5 can't remember and thanks for the other info good to know about that
330 is "ok" depending on the use...I upgraded from stock 32 calipers to brembos and later to wilwoods and every step was a huge improvement!
Discussion Starter · #12 ·
That's the only thing I'm not to sure about is will they be good and big enough or will I have to get bigger wheels and even bigger brakes
I've got for sale a full set of R33 GTR Brembos, along with some EBC Ultimax discs and Pagid RS29 Pads.
Discs and pads done barely any miles and really improved my stopping power - Believe the pads are ceramic based rather than carbon based so work quicker and longer, they cost a small fortune new.
If you're interested there are more pictures here; R32 R33 GTR Brembo Front Rear Brake Calipers Complete w/ Discs & Pagid RS29 Pads | eBay
For sale outside of eBay at £800 :)
Cheers,
Alex
1 - 14 of 14 Posts
