No baffles, so dont see the point other than to run more oil, if I was buying a sump now Id go for the MAD one from sweden, I modded mine so it actually works like a bigger sump should, most of the ones like in the pic the spacer for the pick up isnt even long enough , i added 8mm to mine.
Discussion Starter #4
Perhaps I should speak to you about modding the OEM one to add 8mm and baffles? I need an annual service next month and I believe you have a specialist GT-R shop in Crawley?
You would be better off buying the one you list and Ill add the baffles, you can post to my mate who does my welding, or getting the MAD one, the stock one to mod would work out the same as the billet one and the billet will transfer heat a little quicker, both will need the tray cutting out around the sump.
