i have bled the fluids through(old fashioned way of tube to bleed nipple , fill resovoir and bottle and pump the pedal)
are there any better ways.
i do not have a compressor though.
and how on earth do you bleed the 4wd system properly.
did bleed it properly but light still staying on.
any advice would be appreciated.
thanks guys.
attessa bleeding
mate if you aint bled it yet there's a plug under dash you can disconnect which allows pump to run without engine running p.s soz just read your post again you got r32gtr im going on r33 will check manual for ya when i get five might be same set up
Remove the driverside kickpanel next to the throttle pedal, undo the white connector that has a black and yellow/green wire running through it.
Jack your car up and bleed the attessa at the connector that has a big steel reinforced line running to it on the back off your gearbox under the rear prop until no more air comes out the nipple.
Connect the connector at the kickpanel again and try. If the light in the dash doesn't go out, check the fault code in the boot for another problem;)
Good luck :thumbsup:
