Here goes...
First, set the Boost Warn
Turn the Mode knob until you get the red display with the WARN icon blinking. It will either showing a boost value like 0.00 or a Ratio reduction like -10.
Pushing the Volume knob selects between the desired warning level of the boost and the Ratio to be reduced when reaching the limiter. Choose the boost warn first.
Turning the Volume knob increases or decreases the desired level. When done, push the Volume knob again to jump to the limiter Ratio display.
Turning the Volume knob increases or decreases the desired Ratio (0 means the limiter is OFF !). The value you choose will be used to reduce the current Ratio when running with the settings "1" - "4" (0...-99). so if it reads -10, a Ratio 40 will be reduced to 30 when the limiter is hit.
Now the Scramble:
Turn the Mode knob until you get the flashing "L" icon. The display will show either the current set Ratio in/decrease (e.g. P10 or P-5) or the time setting for the scramble feature (e.g. C 3).
Pushing the Volume knob selects between setting the Ratio to be reduced or increased when reaching the limiter. Choose the boost warn first (see above)
Turning the Volume knob now increases or decreases the desired Ratio (0 means Scramble is OFF !). The value you choose will be used to reduce or increase the current Ratio when running with the settings "1" - "4" (P99...P-99).
So if it reads P10; a Ratio of 40 will be increased to 50 when the warn level is reached.
When done, push the Volume knob again to jump to the Scramble time setting display.
Please note, a Ratio increase could cause too much boost and your engine can be damaged .. so be careful when experimenting with these settings.
Here turning the Volume knob increases or decreases the time for the Scramble feature (0 means Scramble is OFF !). The value you choose will be used to keep the Ratio at the value for a specific time in seconds (C0...C99). So C3 means that the new Ratio will be held for 3 seconds.
Please note, if the scramble feature is active and the WARN level is reached again, the timer is reset and starts again.
There's no need to store the values. Just turn the Mode knob to go back to one of the Ratio Presets.
Hope that's clear!
