I sent my cylinder head and block for resizing the bore. So after reface the block
and thecylinder head what head Gasket is required? As I am going for rebuild is it required to do machine
work to the cylinder head and what is required to do for Springs, valves, seals, guides
etc..? BTW bore size will be 86.5.
well the thickness of the headgasket is depending on the internal you are using and what your engine will be build for. Em if i remember correct we used on our the HKS 1.2mm gasket.
MHG
I am going for a small rebuild. CP or JE Pistons at 86.5 mm bore, and I might keep the stock conrods, it depends on the machine shop to decide wether it is usable or not. also with the cranckshaft same concept :smokin:.
Ahmed
