1 - 12 of 12 Posts
Right guys,
I'm getting a bit stressed with this. my Bluetooth audio tends to skip like its a CD playing. I'm not sure what to do with it or how to sort it or if anyone has the same issue. I am running apple music through the Bluetooth if that helps.
Just play through a cable mate, plug it in to the glove box and leave it, the Bluetooth will still work for the phone calls etc
You could check that you have the latest firmware on the car bud
Thanks for the reply man, It's through my phone so don't really wanna put it through a cable when I have Bluetooth. How would I see the latest firmware?
Thanks.
It***8217;s buried in the info page bud on th MFD, can***8217;t rememebr off the top of my noggin but it***8217;s defo there somewhere lol
The cable is better than the Bluetooth and it***8217;ll charge as well which is a bonus
Is there an AUX port in the glove box to connect a cable?
Mine skips as well it drives me nuts!
If you have a NAV car there is a USB slot in the center arm rest, sorry not globe box......
Ah right! I was unaware you could play music via that USB port I thought it was just for charging things.
That USB port is usually taken up by my misses charging her E-cigarette :chairshot
There are two ports, one connects to the HU and one is a 12v port you can plug a charger into
Sounds like she is going g to have to make sure it’s charged before she leaves the house now then lol
I have the same issue it's frustrating, thought it was my phone but then tried others and the same happened. Will try the cable option.
1 - 12 of 12 Posts
