For Skyline BNR32
Ultraracing Front Lower bar, new 80€/70 GBP
Ultraracing Rear lower bar, new, 80€/70 GBP
Purchased from Automac
Pics of both and how the work:
Rear Sway Bar,Stabilizer Bars Manufacturer Malaysia,Custom Strut bar,Aftermarket strut bar,SUSPENSION and shock absorber PARTS,Performance Part distributor
I might lose these new Cusco´s if someone is interested (going to switch Ikeya F front bars, wich comes with reaction bars as standard, so these can go) 200 € / 175 GBP (retails over 300 € / 260 GBP)
Suspension arm English page CUSCO
Contacts via private message, products in Finland, will ship worldwide
Sam
Pics
Check out the names of the items:
Front Lower Bar / Front Member Brace -pic shows to braces, this is the upper one, Code : UR-LA2-479A. It connects the 2 front reaction bars together, making the front rigid. Check the other link how this effects your car.
Rear Lower Bar / Rear Member Brace is the one with Code : UR-RL2-483. It´s attached to rear axle and axletray. This can be used to make back setup with rubber bushes more solid as would aluminum bushes do, without becoming too solid.
