1 - 19 of 19 Posts
hi
every time i turn my car off (32) the coolant boils almost instantly, ive tried changing the coolant and put some water wetter in it but no change. temp whilst driving normally is usually about 80-85 degrees is this hot or normal? and why is it boiling.
thanks
Could be a leaky hose? I had one of mine get a small hole in it caused very little water loss but a boiling sound after the engine was turned off.Changed the oil cooler hose under the inlet manifold and the noise went away. 85 to 90 deg is fine
ok ill have a look thanks, could it be that for some reason my engine is running hot and thats whats boiling up the coolant after i turn it off, but i assume that the coolant temp is a direct reflection of the engine temp whilst driving?
i only bought the car a few weeks ago, so i have alot to learn about whats normal and whats not yet. but engine does feel crazy hot after any kind of drive.
Make certain that you bleed the cylinder head - 10mm bolt at the front of the head on the inlet plenum adapter plate.
Make certain that the radiator is full - take cap off when engine is cold to check.
Once you start it make sure that the hot water is coming from the water pump - likely to be the thermostat if is not.
If the above checks out then prepare for some bad news, the worst being a cracked head and the best being a head gasket.
ALL IMHO
Discussion Starter · #11 ·
i do have a mystery fluid leak somewhere its only very slight but i cant see where its coming from, all i know is its not engine oil and its above the front tow hook perhaps this is leaking coolant hose somewhere and causing my problem.
i have also orderd a nismo rad cap and a new thermostat.
defo rad cap, mine was making the same pulsating 'surge' noise post shutdown......water rushing from the rad to the expansion bottle......
all looked fine on the guage, but i decided to swap the cap to a spare one and all sorted.
Boiling on turn off
Check the water pump itself for signs of leakage from the tell tale hole.
Discussion Starter · #16 ·
how exactly do i bleed the cylinder head when im putting coolant in?
do i just take screw out or do u have to take it out and do something else?
1 - 19 of 19 Posts
