Hi, I'm new here but been lurking around for awhile .
I recently came across this problem after i came back from overseas . Basically i left i car at home for 1 month but have someone regularly starting up the car . After i came back the hood pop up (Red light) ,VDC (Yellow) ,Traction control (Yellow) and ABS (Yellow) came on . I open the bonnet then close again . The Hood pop up light is gone and after a short drive the rest of the lights is gone too . after a while they all came back up again . From what i can see is that the left side lower corner of the bonnet is slightly mis align when closed lightly but when closed from chest height it closed flushed and normal .
Would like help and advise on what I should do from here .
Thank you in advance... :wavey:
