1 - 14 of 14 Posts
Slippery?
Isn't that the Turbo timer you are referring to?
I have a Greddy boost controller going back to the main topic (Jamies question). Although it doesn't seem to have the OTB (over take button) working, just a case of reprogramming it i'm told!
I will be fitting an HKS EVC IV to my car. I managed to find a limited edition version which has a whiteish backlight which matches with the backlight for the aircon.
Anyway it is not that hard to set up and program. If you go to hkseurope.com you will be able to read both the setup and fitting manuals...good place to start to get an idea on what to go for.
The others, Blitz or Trust are also good but i really don't know anything about them
Oh...and the HKS EVC comes in 3 specs EZ(very simple functions) EVC IV and EVC pro
Boost controller
Jamie,
The combination of the Trust/GReddy PRofec B, and a SPA digital boost/temp gauge is unbeatable. :D
You can setup overtake, over-boost, high and low boost levels. :)
The SPA gauge is accurate to + - 1 psi, can be programmed for over boost level (a built in lamp flashes) and has a built in temp gauge. I have mine monitoring the intake air temp. :)
I had to install it all myself with a lot of advice from Shin, as nobody in Germany knows how. :confused:
Could give you easy to follow instructions if you wish to do the same.;)
Regards Paul.
Yes you are correct and I am as stupid as the stupidist man in
stupid town.
It is the turbo timer.
But you should have both anyway.
Cheers Tom.:smokin:
1 - 14 of 14 Posts
