1 - 11 of 11 Posts
does anyone know if the euc on the er34gtt rb25det neo has a boost cut system as standard ?
if so what does it cut at
thanks ian
Hiya Ian - Before my EBC was fitted I was running 1bar via a tweaked accuator and when it spiked to over 1 (gauge only shows upto 1) there was a fuel/boost cut. Felt like I was slamming on the brakes it was that sharp and was on & off until I stopped accelerating.
yep
yep thats the same problem i am having
must down sise my nos jets then for the time being
till i get my e-mange and bbost controler
Just be careful with your injectors, theres now lots of us GTT's (with PowerFC's) showing 95%+ inj duty on the Commander at only 310-320 bhp :eek:
a
bigger injectors
i never had this problem with my 33gts25t
was running 376bhp on standard injectors
bloody neo engines
I am one of the aforementioned that has run out of injector duty and would be suprised if I were even that high in power mate...
Nick - Josewick was the one I was thinking about, I didn't realise you had yours in yet, damn your catching up fast :D
Discussion Starter #9
ok
what injectors should we use then
as my nos system is wet it injects fuel as well as nos so this should help some what
They are top feed high impedance Ian so not the same as any other Skyline model other than possibly the RB20DET - I have ordered some from NZ for very sensible money and will let you know next week if they are an option, otherwise Nismo Purple 480cc run at about £500 for the set.
1 - 11 of 11 Posts
