Marv,
Make sure before you up anything, that the info you are working from is relevant to your car
The GTS-t stock turbo will fail rather quickly with anything more than about .9bar boost. Fueling will be the limiting factor beyond this anyhow, so play safe.
marv said:
What is the best way too up the boost ?
And What is the cheapest ?
And The easiest. ?
The best way to up the boost, is using an electronic boost controller.
The cheapest way to up the boost, is using a bleed valve.
Either way is easy, but you will need a reasonably accurate Boost Gauge before attempting to do it with a bleed valve.
R33Vspec Karma,
That's pretty duff advice you've given above, Marv asked specifically about the GTS-t, and there is nothing cheap about the Greddy E-Manage when you need a laptop to program it.
