Hi
When under a light load my turbo spools up very easily, too soon. On the Apexi it goes from - to + boost fairly easily. Especially in a higher gear.
What can cause this? Weak acuators? Leak?
I have set the AVCR to the most minimal settings ie duty etc and it still does it. When i switch it to off mode its slightly better but still boost way too easily.I am having to feather the throttle to it wont boost so much.
When on boost its uneven when building up pressure (deoending on the amount of throttle) and it wont hold stable boost without it feeling on and off.
Any ideas?
Thank you.
Any ideas?
Thank you.
