Never had a problem with mine leaking at all.......dont think its a general fault on these cars..........but from experience id say it may be down to a repair from the past that may have not been repaired correctly or a split boot rubber.
Take your boot rubber of and check.........or at least try and work out where the water is leaking in from.....if the rubber is good then check things like panel gaps.......
